BISS CI Module
BISS CI Module
Legal Common Interface modules with support for the BISS CA system defined by the EBU are hard to find. After requests from several customers we decided to build one. Here it is.
Features
The cam can store up to 4 different keys for BISS Mode 1 in the internal memory. You can enter three keys for three different services (identified by their service id) and one default key which will be used for all other services.
A total of 32 pids (on up to 32 different services) can be descrambled simultaneously. Professional 24/7 multichannel descrambling is fully supported.
Configuration
Keys are entered using the the CI menu. Keys that have been entered once will not be shown again in the MMI once the configuration procedure has been completed.
How to buy
The price per CAM is 89 Euros plus shipping and taxes.
Shipping within Germany and the EU: 6,60 €
Express/World shipping: depends on destination, please ask !
Please tell us how many CAMs you need and where they have to be shipped to. We will then send you an official quote/invoice within 24 hours.
This CAM is intended for commercial use only. We do not sell or ship these CAMs to endusers and resellers. See why...
How does it work ?
Just have a look at the screenshots showing the different menus.
Hardware versions (EOL announcement for old hardware versions 1 & 2)
Several different hardware versions (called 1, 2/2.1 and 3) exist. Existing customers can identify the version they have in the Module Information menu. The high level software and features are identical on all versions. Hardware versions below 3 are however no longer in production and only a very small amount of hardware version 1 CAMs is left in stock. Hardware version 2/2.1 are permanently sold out. Customers requiring additional supply of a specific version should make sure that the requested hardware version is clearly stated in the order !
Limitations
Support for multichannel descrambling (up to 32 pids on 16 services) has been added with firmware version 2.10. A PC-based upgrade software is available for CAMs with Hardware version 1. CAMs with Hardware version 2 can be upgraded using an OTA stream image that is available on request.
www.streamguru.de
  • Like 1
Δεν θα 'λεγα όχι να την είχα...
The same with me if of course I knew how much it costs
My friend... I don't speak... English!!!
14 λεπτά πριν, Ο neoktistos έγραψε
Κάπου αναφέρει ότι έχει κόστος 89€ χωρίς μεταφορικά (+6 μεταφορικά εντός Γερμανίας, αν κατάλαβα καλά)...
In this section we write only in English
17 λεπτά πριν, Ο neoktistos έγραψε
https://www.kosmosat.gr/signal-processing/headends/ci-modules/procam-biss-16-services/?cookies_accepted=Y
Πεταμένα λεφτά. Εχω ένα συρτάρι με πάνω από 10 modules + programmer + kartes. Ούτε και ξέρω πόσα είχα ξοδέψει τότε! Της κάρτες fun της θυμάται κανείς? :default_cool:
Πού με... ταξίδεψες (στο χρόνο) τώρα!!!
Είχα μια "Ροζ" κάρτα το... μακρινό "σωτήριον" έτος, το 2002, την χρονιά που πρωτο-τοποθέτησα το κάτοπτρο για να δω -με σταθερή λήψη όμως- τους τότε HotBirds, που τότε είχαν και τις τότε δυτικές δέσμες! Δεν είχα προλάβει να "δω" το Alpha Digital, όπως και την Nova (την... απόλαυσα με την λευκή  "Gamma" κάρτα, για σχεδόν ένα χρόνο, από το 2008 εως το 2009) που είχε προλάβει να περάσει στην 2η έκδοση.
Η ροζ κάρτα, τότε, μου "εμφάνιζε" τα Γαλλικά "TPS" και "AB Sat", το Ρώσικο RTVi, τα EuroSports, τα Σλοβένικα, τα Κροάτικα σε Viaccess και μερικά στο "SECA", καθώς και τα Ολλανδικά του Astra 1, στο τότε "Irdeto 1"!
Έχω... κι άλλες ιστορίες!
Σχετικά με μοντούλες, είχα κερδίσει την μπλε Zeta Cam που αποκρυπτογραφούσε το... "εκπαιδευτικό" Full-X ("1" και "2" στον HotBird και το "3", στον Astra 1), από έναν διαγωνισμό του τότε περιοδικού "TV-SAT".
Πάντως, είμαι... περίεργος, να δοκίμαζα στην "LG" που είναι στο πατρικό μου και που έχει την δυνατότητα για δορυφορική λήψη!
  • Like 1
  • 1 month later...
Και εγώ φίλε μου έχω συλλογή!!! από από τα  "σύνεργα'' που αναφέρεις...Όσον αφορά τις μοντούλες πέρυσι έκανα  πάρα πολλές δοκιμές το σύστημα μπις. 'Ομως δεν κατάφερα να έχω φως σε μοντούλα τύπου zeta cam και magic, matrix .... πέρασα σ αυτές δεκάδες αρχεία αλλά τίποτα. Φως μόνο σε dragon και diablo. Έχω επίσης μια quattro 4x4 αγορασμένη από Ελλάδα και μια AlphaCrypt Pro v3.28 multicrypt αγορασμένη από το εξωτερικό. Στις μοντούλες αυτές δουλεύουν τα μπις με την διαφορά η εισαγωγή των μπισκότων των σίντ και βίντεο πιντ πρέπει να γίνεται στο δεκαδικό σύστημα και όταν γίνει η εγγραφή μετατρέπονται στο δεκαεξαδικό. Η δεύτερη  έχει την εξής ιδιαιτερότητα που ανακάλυψα πρόσφατα. Στα μπισκότα πληκτρολογούμε μόνο τις πρώτη δεύτερη  τρίτη  πέμπτη έκτη και έβδομη δυάδα. Στην αρχή που την πήρα νόμιζα ότι είναι χαλασμένη ή ότι δεν υποστηρίζει το σύστημα.
Επεξεργάστηκε από sat3x1
